Question about heat ranges in Champion plugs
DusTed74
Oklahoma
Here's my question. If you look at the picture that I took you will notice that the one on the right is a colded than the left.
The heat number on both number 12. You can see in the photo that the numbers are the same except for the hex head.
I would really like to know.
Thanks................Ted
you can extend the tip of the plug or recess it and still have the same range
Those RC plugs are handy if you have headers and clearance issues.
You cannot directly compare heat ranges of different type plugs. They are a "relative" number ONLY in the same series of plugs
You can see this yourself. Look at how the plug is made. One has much more mass. The heat conductivity is much different between the two types.
They also, "by the book" are only a starting place
Hey Ted. I believe it has to do with the in head part more so than the porcelain end. I could be wrong. I thought it had to do with the electrode distance and porcelain under it.
A 12 is always a 12. Doesn’t matter what shell is on the plug.
