MOPAROFFICIAL
Oogliboogli
I haven't heard "Charlie" in yearsCharlies heads are out in the Pacific, they won't be here for Black Friday so order your Trick Flows today
Viet Cong are casting heads?Charlies heads are out in the Pacific, they won't be here for Black Friday so order your Trick Flows today
We call them all Charles.Viet Cong are casting heads?
Not as advertised.
I like this idea, I wasn’t sure if this was something I could do but I did think about it. Thanks, I’ve been thinking about going aluminum for along time. But now that I have to remove the heads anyway I was going to do it, I just wasn’t sure which head to go with. Especially with the lack of availability. The heads I have seem fine if I can enlarge them the cc to help. Thanks againI would need to know more.... but fwiw
1008 felpro-.039 thick
8553 felpro-.046-.048 thick
519sd felpro-.054 thick
"Regular blue felpro" the 8553?
Try the 519sd and keep the good heads you have. If you were close...I could dial all the chambers in=enlarge them. I think you can fix this without changing something as important as the heads
Retail name is " Ho-Ho Chi Minh" because lots of guys buy them at Christmas...Viet Cong are casting heads?
I got stung once when they were Pro Comp...never again. Same for CAT.Not a friendly website for sure. Cheap parts, cheap website.
