73plumkrazy
Hey y'all, got to pick your brain. I've got a 73 dodge dart sport 340, had it for a couple months now. I had a few electrical issues and finally rewired the whole car. Somewhere in the mix, ignition coil got fried. Replaced the coil, the ignition control unit, and the ballast resistor. The car Started and ran no problem, until it died while I was driving. Wasn't getting a spark. So went through my typical checklist, everything checked out but still nothing. After awhile, went to start it, started like there was never an issue. This happened a few times. The pattern seems to be after it had cooled off a bit, it would start and run. My initial thought was the coil was overheating and it was protecting itself. So I replaced the wires and spark plugs, they probably needed to be addressed anyway considering the wires were 7mm and I replaced them with 8.5mm. Anyway, it's still doing the same thing, seems fine until it's hot, then the car dies with no spark until it cools off. The only thing that hasn't been given any attention is the distributor. Any ideas?
