jcolman
My temp gauge (brand new autometer) indicates that my engine rarely gets above 150. Only on the hottest days does my motor show a temperature of 180 or higher. I'm guessing I should look to replace the thermostat?
Thanks. I'll pick one up.No, you should verify first, before you turn a wrench or you're just guessing. Infrared temp guns are cheap. You should already have one.
I thought that if the thermostat was faulty and open all the time, the engine would run too cool. Maybe I'm wrong?Thermostat only controls the temperature that coolant is allowed to begin flow out of the emgine to the radiator. Radiator capacity and cooling fans will have more to do with how hot or cool the engine actually runs.
By the time you get a temp gun, you will have driven yourself insane trying to figure this out. The car will still be THERE when you get the temp gun. Relax until you can verify something and then start diagnosing. You have nothing concrete to go on right now.I thought that if the thermostat was faulty and open all the time, the engine would run too cool. Maybe I'm wrong?
Absolutely that's a good idea if he has one. Dang you are cheap. Them temp guns are well under 20 bucks now. lol I'm right there with you. I'm cheap as hell too, but I do have a temp gun. lolI use my wife's candy thermometer stuck in the radiator, with the cap off of course. I just let them idle up to temp and see if the gauge reads the same as the thermometer.
But, I'm cheap.
What radiator, fan, water pump setup on what motor we talking about? I’m running 175-180 with BeCool rad, high flow pump, dual electric fans, no thermostat... if I leave both fans on during a 60mph Run, car will be running 160 or so...
Good question. I'm not sure. The car is in the shop at the moment getting power steering installed. I'll have to take a look see when I get the car back.Where in the system is the temp sender located?
340 .30 over. TRW flat top pistons. Mopar steel crank, Mopar performance rods. ARP fastners. Holley Sniper EFI with Hyperspark distributor. Edlebrock Aluminum Heads. Weiand Aluminum Intake. hydraulic roller cam. 490/490 lift, 262 duration. 10.5-1 CR. MSD Blaster SS Coil. 8mm Plug Wires. Aluminum Radiator. 6-Blade Aluminum Cooling Fan. Hooker Ceramic Coated Long Tube Headers.
I have no idea what the water pump set up is other than it appears to be stock. My engine use to run around 160-170, sometimes reaching 190 on a hot day. Now that the weather is cooler, I haven't seen temps over 150 even after running for 20 minutes.
I just changed the coolant to Prestone 50/50 prediluted. I don't know what was in the system before. But the car started running cool as soon as the colder weather set in before I changed the coolant. After changing the coolant, I think it's running even a bit cooler now.What’s being used for coolent?
Well, it's not your problem, but I never buy 50/50. It's a ripoff. You're paying for HALF water. Think about that.I just changed the coolant to Prestone 50/50 prediluted. I don't know what was in the system before. But the car ran cool as soon as the colder weather set in before I changed the coolant and runs cool now.
Yeah I know but I was in a bit of a hurry.Well, it's not your problem, but I never buy 50/50. It's a ripoff. You're paying for HALF water. Think about that.
No I don't.Are you certain that there is a thermostat currently installed?
I would not worry about it.340 .30 over. TRW flat top pistons. Mopar steel crank, Mopar performance rods. ARP fastners. Holley Sniper EFI with Hyperspark distributor. Edlebrock Aluminum Heads. Weiand Aluminum Intake. hydraulic roller cam. 490/490 lift, 262 duration. 10.5-1 CR. MSD Blaster SS Coil. 8mm Plug Wires. Aluminum Radiator. 6-Blade Aluminum Cooling Fan. Hooker Ceramic Coated Long Tube Headers.
Except he is efi, and the efi system doesn't even "learn" until it hits 180. So he is basically driving around with the "choke on" 90% of the time if the Temps he is claiming are correct.I would not worry about it.
A lot of forum members would kill for those coolant temps.
