[FOR SALE] 11.75 Pin Type Calliper Brackets
gmachinedart1
Active Member
Rating - 0%
0   0   0
11.75 Pin Type Calliper Brackets. Bead Blasted and Painted. $135 includes shipping in the U.S.
First Person to pay pal me gets them
I take it this allows for larger front rotors on an A body? What spindles does it work with? I have disk brakes on the dart now but don't believe they're that big. Would be nice.
Works on 73-76 A body Disc Brake Spindles.
Hmm, unfortunately I’m not sure which spindles are on mine. I’ll have to see if I can figure it out.
Use rotors for a 1978 Cordoba, and calipers and pads for a 1971 Charger. Hoses are the kind that screw directly into the caliper with a threaded end and use a copper crush washer. I *think* mine were for a 1971 Challenger, but you may need to experiment, or have them made. Great brakes, and these adapters are scarce and usually quite a bit more expensive than this.
2nd in line?
You are actually first in line. Nobody has made an offer. First to Pay pay the $ gets the goods.
send to( no addresses allowed in public forums)
