A wily subterfuge!Well that makes little sense.
Yes, you have a dealer installed A/C, but you have NO A/C?
There you go.
Makes sense.
Factory AC= 3 hole mount.
Non A/C. = 4 hole mount.
Yup. Thanks 4spdragtop for clearing that up. Should be Easily fix to change the mountThere you go.
Makes sense.
Go figure. My blower motor just started working again out of nowhere. Must've healed itself.
Like any motor with windings, a smack with a light hammer usually gets it going, for its last hurrah.Go figure. My blower motor just started working again out of nowhere. Must've healed itself.
This is from our 67 cuda with factory ac. I also have 3 non ac 67-9 cuda heater assemblies and all 3 blower motors are identical to each other, BUT different than our factory ac blower. AC blower has 3 mount holes to firewall. The 3 NON A/C ones I have are all 4 bolt mount. Also you can see where there are 2 machine screws in ac blower. Non ac has rivets.
Hope this helps.
your motor is not clocked to the right position. That round hole on the side should point down and is connected to the tube below by a rubber hose.
There are 2 different sets of photos there. The one set has a blower motor that should have a cooling tube. The other set does not have a cooling tube. I doubt that a '67 ever had a cooling tube.
Interesting Jim, your motor has rivets as opposed to machine screws/nuts on motor housing. Yours looks similar to the 3 non ac blower motors I have.
Cruze, I'll have to dig out part #'s to see if I can muddy the waters more lol
great observation!!! When I sent my ac heater box to Mr Heaterbox for restoration, they send the motor to a 3rd party. They may restore it OR replace it with another similar one as I later found out. My original (with nuts) was replaced with the one shown!! I was NOT happy The wiring is also clocked wrong compared to the original.
Told them they should have advised me before doing that. Ggrrrr, mumble, mumble etc
I sent all my tachs and gauges to Redline. Never a problem, other than looking under the mattress for more US$$$$!I dont blame you for being unhappy. We had both our factory tachs(67 and a 69) done by them. We actually dropped them off, Dads 67 hasnt worked properly(reads high) since day 1. They are aware and will fix, but as we know these tachs are a pita to remove!
