Engine Turns Over With Key Off
Tims 66 Cuda
Mopar mid life crisis
Poquoson, Va
I,m having trouble finding out why the starter turns with the switch off when I connect the battery switch I,ve checked the starter wires an grounded the NSS. I,m at a loss. Any help appreciated
Thanks, Tim
your relay is bad or shorting 3 to 1 at the big nut. power to 4 energizes contacts 1 and 3 together to complete circuit. Check wiring.
?u=https%3A%2F%2Fi.pinimg.com%2F736x%2Fe8%2Fc6%2Fb1%2Fe8c6b116329e0354ed0d492d78065a8f.jpg
?u=https%3A%2F%2Fwww.forabodiesonly.com%2Fmopar%2Fattachments%2Fdartstarterrelay-jpg.jpg
just check for switched voltage on 4 from key. could be ignition switch.
