I have a S6 73 Dart with manual drum brakes. I bought a spool mount K member to swap to V8. Do I have to switch to disc brakes. The K member has the lower control arm attached. Any help would be greatly appreciated. Thank you.
I cant remember for sure but I think the big ball joint went standard in 73. Hopefully someone can chime in and say for sure.
For a cruiser there is nothing wrong with drum brakes. If you have the disc spindles, etc I would run them but run what you have. You can always change to disc later if you dont like the drums.
