Upper Control Arm Adjuster Bolt/Cams
RogerRamRod
The Older I Get, The Faster I Was
Chesapeake VA
I’ve had my car apart for longer than I care to admit. I’m not able to see if this makes a difference, but is there a preferred or correct way to install the bolts?
Both facing the same way, Forward or Rearward?
Or
Both with the nuts to the outside, or both with the nuts to the inside?
Thanks in advance for any info, I did try and search, but didn’t seem to find an answer.
