That's a great idea. You can get a borescope attachment for a cell phone cheap.Can you use an inspection camera and access at the dome light or sunvisor?
Newfoundland is not a huge province, so I will ask if you know Fitzee who has the welding/body repair YouTube channel.Yup! That's the conclusion I came to with my car. Front of roof was pushed in by a previous accident that buckled the roof and support frame. Way to much time to repair so I bought and installed a complete roof from another car. Not nearly as difficult as it seems to do . Just measure carefully and take your time.
Fortunately I was able to fix it easily. I just needed a stronger magnet! While not 100% perfect, the dent is not really noticable anymoreIt would be really cool if you could fix it easy. I'm not tryin to be negative, just realistic.
Seems the, depression is taken care of. Needs some viagra now.Does anybody think Lexapro could help cure the depression?
If you scroll up a bit, you'll see that I was able to pull the dent out with a strong magnet.FWIW, I have a dent in my roof as well and I took it to a paintless dent repair shop. He uses the rods and levers to push out dents. He said he only works on cars 10 years old or less as the metal is too thick to do his work. He said a big hammer and dolly "may" help, but I needed and old fashioned body shop to do the job. I don't have a headliner in right now. Not trying to hijack thread but wanted to clarify that our cars may have metal that it too thick for paintless dent repair.
I read the entire thread. I agree that with yours that it could just be popped out. Creased panels like mine cannot be manipulated with the rods and levers of Paintless dent repair. I would love to know what kinds of magnets you have. I will try anything not to replace my roof.If you scroll up a bit, you'll see that I was able to pull the dent out with a strong magnet.
FWIW- Just as an aside to your statement (and others) about creases. When I was the Service Manager at a Harley dealership in NJ we had a young guy who learned the Dentless repair trade while working for Mercedes Benz. Cars coming off ships with dents yada yada. He repaired a few Harley gas tanks with custom paint and he only had access though the fuel fill hole. Slow manipulation of different lengths and shapes of rods and thoughtful correct tapping with his hammer performed miracles that if I hadn't seen it, I wouldn't have believed it.I read the entire thread. I agree that with yours that it could just be popped out. Creased panels like mine cannot be manipulated with the rods and levers of Paintless dent repair. I would love to know what kinds of magnets you have. I will try anything not to replace my roof.
Hell yeah.Good news! I have an industrial magnet that is much stronger than the cheap one I originally used. There is indeed metal under the depression. I used the stronger magnet to pull up on the indention and popped it out! It's interesting that the original magnet (one of those that you use to hold photos on your refrigerator ) would not pick up on the metal in the depression but would stick to the metal around it. Anyway, I still might have to reinforce the roof if it oilcans again on me.
Man that's awesome. I'm glad it ended up bein a lot easier fix.Fortunately I was able to fix it easily. I just needed a stronger magnet! While not 100% perfect, the dent is not really noticable anymore
That's good news. Hopefully it will continue to maintain it's shape. From what little I know about metal stretching I believe yours is a temporary "fix". Good luck.If you scroll up a bit, you'll see that I was able to pull the dent out with a strong magnet.
I bought mine about 12 years ago but they are similar to these:I read the entire thread. I agree that with yours that it could just be popped out. Creased panels like mine cannot be manipulated with the rods and levers of Paintless dent repair. I would love to know what kinds of magnets you have. I will try anything not to replace my roof.
Thanks. I was surprised to find that there was some good metal there! But, as mentioned, it might be a temporary fix until I can find out why the metal collapsed in the first place.Man that's awesome. I'm glad it ended up bein a lot easier fix.
I wonder if that center support that the dome light mounts to has been pushed down too? It's worth a look with a borescope like we talked about earlier.Thanks. I was surprised to find that there was some good metal there! But, as mentioned, it might be a temporary fix until I can find out why the metal collapsed in the first place.
I'm sure that the shop that will be doing the transmission swap will have one. I'll have them take a look.I wonder if that center support that the dome light mounts to has been pushed down too? It's worth a look with a borescope like we talked about earlier.
