Bad bad bad idea
The part welded to is not steel, looks to me to be malleableBad idea the way it was done....or just a bad idea, period?
So...great idea, lousy execution?The part welded to is not steel, looks to me to be malleable
Malleable is not good to weld on let alone anything that involves strength
Those tacks welds are inadequate for the tonnage of the jack no matter what the base material is
Lousy idea and its dangerous.So...great idea, lousy execution?
I've got enough holes in my head already! Even MY welding looks better than that rigged up POS, and I am no welder. If something won't come right apart with the pressure exerted by the puller in its original form, just tighten it up as far as you can get it, and let it sit a while. A little heat may help, but there's no reason to build an explosion waiting to happen.
