340wedge Well-Known Member Joined Nov 14, 2004 Messages 1,141 Reaction score 824 Mar 4, 2022 #1 Has anyone replaced their 8 3/4 rear end fluid and if so how did you do it and what fluid is recommended? Thank you.
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,295 Location Idaho Mar 4, 2022 #2 Read the book. RTFM. Go to MyMopar and download a free service manual. Some of them there are so because of guys right here. Does it have limited slip? If not I'd just run to the "parts store" and buy some multigrade gear lube
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,965 Location las vegas Mar 4, 2022 #3 drill and tap bottom of housing 1/8 plug
CRUZE 418 FABO Gold Member FABO Gold Member Joined Mar 11, 2019 Messages 2,231 Reaction score 1,383 Location Illinois Mar 4, 2022 #4 Flush it, don't just drain it after you drill and tap for 1/8" pipe plug. Then 2 qts of 80/90 gear lube and sure grip additive if it's a positraction diff. That's for the 8 3/4 . O'Reilly Auto has the additive.
