You either didn't read or did not understand. YOU MUST tie the ign1 and ign2 together to get the MSD (or any other non ballasted ignition) to work, because IGN1 "run" GOES DEAD in crank, so you need IGN2 "bypass" connected to fire the thing during crank
HERE ARE THE ONLY outputs on a Mopar ignition:
ACCESSORY.........hot in either accessory or run, this obviously powers...."accessories"
RUN, IGN1, this is hot ONLY in run and goes DEAD in start. Runs the instrument panel, warning lights, and goes out into the engine bay, and powers the ignition, the alternator field, the VR, electric choke if used, and some smog doo dads on some models
BYPASS, IGN2....hot ONLY in crank, this goes out into the engine bay and connects to coil+ end of the ballast (usually brown) and provides THE ONLY power available to the ignition for start
START, often yellow.......goes to start relay to initiate starter. In '74, this goes through the seat belt interlock box. This contact on the switch mimics BYPASS but is a SEPARATE contact and is done to prevent circuit backfeed
YOU MUST connect IGN1 and IGN2 together, either at the switch or out in the engine bay and use that to power the underhood loads
