Which intake is better for a weekend cruiser? Engine has J heads on it. Do I need the exhaust heat crossovers that the RPM intake has or would I better off with the air gap intake that doesn't have them?
Post is almost 8 years old, kinda late to reply now. I'm sure that the issue was solved year's ago@jmwuva05 disagree all you want, people have done it...case in point in link below
dual plane divider
as to whether or not it helps, I believe the alleged reason is to alleviate potential mixture distribution problems, but I've never experienced that...
pertaining to hood clearance,the RPM will fit where the airgap won't.
Oops I was reading this post and my fat thumb must have hit disagree@jmwuva05 disagree all you want, people have done it...case in point in link below
dual plane divider
It’s a win win. The AG should be just fine down south. The regular RPM that heats the intake up will be good for a vehicle that is more gear round and closer to daily rather than weekender. This is a plus in the winter when I gets down right chilly to cold.Thanks for the info fellas. I guess I will pick up whichever comes up for sale first then.
[ame="[MEDIA=youtube]i2DvnoHWagk[/MEDIA]"]Edelbrock Intake Manifold Dyno Test :: Single Vs Dual + Air-Gap Vs Regular - YouTube[/ame]
