Was told by Summut there is a difference
If there is a difference what is it. ??And?
Thanks, Im talking about head gaskets
Whats the part no on the magnums ?
Geez, you need to do some homework.Whats the part number in the magnum ones
Compressed thickness ?
CometicThats good, i found copper head gaskets 4.060 bore.. Too much $$ and theyre .080 compressed. Im Looking for a steel set at .040 -.050.
My understanding is that with cometics the deck should be resurfacedCometic
Great question !ant the difference sumptin bout a hole to let oil pass threw to the heads vs magnums push rod oiling?????
I asked Rumblefish to put the gaskets on top of each other and see if there were extra holesGreat question !
CorrectMy understanding is that with cometics the deck should be resurfaced
