4 weeks to button things up. Trying to move from 8.2's to 7.9's in the 1/8th. Hopefully they'll run 1/4 and it will get to mark it's first 1320 pass. Already did manual brake swap and small crank pulley. Still need to :
Getting close enough to get excited now
- Kit for the carb
- Flowmaster FX straight through mufflers
- Hopefully some passes to mess with shift points and timing games....
Sounds like you're on the stairway to 7s..
