[WANTED] V8 throttle pedal for my A body
You should only need.the correct cable and depending on what throttle cable bracket and intake you use, the slant may be the best!
/ 6 and V8 takes a completely different setup. Not just the cable.... FYI At least early does.....
The cables are different lengths and the slant ones are the longest. Yes the brackets are engine style dependent but he doesn't need an accelerator pedal assy.
Through 66, slant sixes had a rod, not a cable.
If the OP is working on a 65 Barracuda, he will need the V8 accelerator pedal, V8 throttle cable firewall bracket, and an A body V8 cable, preferably a four barrel cable. Repop 340 cable will work just fine.
Edit, if you don't care about looking original, a later A body swing pedal setup can be made to work with just a bit of trimming.
connecting to a Rochester Quadrajet as of now
I didn't realize he had no cable to start with. Been a long time since I had a rod carb linkage set up on a slant. I forgot. Forgive me.
I used a 73 Duster 318 2bbl throttle cable on my 66 Valiant with an M1 intake on my 340.
