Yeah, I tried to find a picture of the inside. I ain't spendin days lookin. lolThe 90 degree fitting on the outside needs a matching drop tube on the inside going to the bottom. If it has that, then it'll recirc
Cool thanks for that. I've been looking for one compact enough to fit Vixen and that might be it.The top hose barb fits 3/8" hose, and is screwed into the tank w/ NPT threads & sealant to prevent leaks. This hose barb could be removed and replaced w/ another size if needed, as long ans it is resealed again to prevent leakage. There is a tube inside the tank that extends to the bottom of the tank and this allows the coolant to be pulled back in the cooling system. This top hose barb is connected to the radiator w/ a hose that attaches near the radiator cap (on most radiators - this is the only connection to the radiator and this hose works for overflow & recovery of coolant). This info is included with description
Can you give us a good shot of the inside of the can please or report on whether it has a tube that runs to the bottom of the inside of the can? Thanks.Thanks for all the feedback and discussion.
This site has been very helpful as I start this project.
Where? lolHere is a shot
