skep419
No show, all go!
1966 Dodge Dart (California Car) - cars & trucks - by owner -...
$7000
Not sure what makes it so rare?
The ad is wrong. This IS NOT a factory air car. Has the non-air heater panel and firewall, an aftermarket compressor without the drive belts, no condenser coil in front of the (incorrect replacement) radiator and radiator cap, a single pulley alternator, and an aftermarket evaporator unit under the dash. The refrigerant hoses are routed through two large and poorly sealed holes drilled through the firewall. This looks like a Sears bolt-on a/c system which was never completed and made to be operational. The EGR system has been removed, as well as the evaporative emissions system, the distributor vacuum advance delay, and the heated air bypass door. The heater hose valve cover bracket is missing, and the heater hoses are misrouted through the evaporative emissions hose loop on the right inner fender. The ECU, voltage regulator and PCV valve are all incorrect aftermarket replacements, as are the ignition cables which lack the rubber grommets that seal up the spark plug tubes. The ad says that everything works, but the a/c will not operate without drive belts or a conderser coil. The body looks pretty nice, though. Brand new trunk mat with the folds from the shipping bag still there. The rear window defogger is factory - a fairly rare option.
$7000
100 pages and I don't think anyone has bought any of these
Still fun to see what's out there.
Way cool! Even if I wasn't gonna use them, they'd look great hanging in my garage.Looking for home on 32 Roadster. Must be BB Mopar powered
Long Ram Dual Quads Intake - auto parts - by owner - vehicle...
That looks like something I gotta have. So how come it hasn't sold after being posted for four days? Something must be up with it??Dang! Within easy driving distance. I'm afraid to call and offer him a grand for it, lol. That's what I need, is one more old truck to work on!
