RevboxRyan
So I bought a 74 Dart Slant 6 car it has 5x4 pattern and drum all the way around. Didn't larger pattern start in 73 or 74? And 73-76 have different ball joints correct? And as far as brakes and larger pattern upgrade I've search and FMJ body cars are donors for brakes but are rare around here in yards. ANY C B or E body stuff work? Have to change spindles to fit newer brake parts? What else have people used for brake upgrades and large lug pattern? Not really into Wilwood setup if it's custom stuff only available through them or a dealer especially with current supply issues. Is there any aftermarket K frame that uses torsion bars and rack and pinion. Seems every rack one is coil over. Looking for under hood room Basically. Cars getting mini tubbed sub frame connectors and boxes. Going to be a street strip car. I'm a 72-93 truck guy so don't know that much about the A bodys.
