mine is disk drum manual slider braket single pot like post 73 US cars just mine are girling girlocks. Rear are 9 inch drums like 60s US or Canadian /6 Abody cars just with 4.5" pcd
I found that a brake bias for the rears really made a difference.
9 inch rear drums are tiny compared with most US cars, 60s style, duo servo, self activating, ditch finders....
they could lock up before the front were hard-on
bias helps with that..... allows fronts to work at proper disk brake caliper pressure without the back drums being full on from the get-go.
the right bore MC makes or breaks the install....
too narrow and the pedal hits the floor, or at least gives that impression, too wide and the brakes feel like the pads and shoes are made from wet wood, hard pedal, no progression and too many close encounters with the rear end of trucks.
definitly heed the advice in posts above regarding MC bore
Dave
