60Powerwagon
Active Member
It’s hard to believe that every one of those was working fine and now one isn’t. I’ll see what I can figure out. I have a truck I can swap some parts from to try. I’ll have to look again, but I believe it has the silver ignition box.well, means you did not pull the cam, remove the chain, and you've advanced/retard the timing, I would say either fuel delivery or something is wrong with you Mallory distributor. OR..... what ECU are you using? Could that be playing games?
