Cleaning up for paint and noticed a rivet missing. Looks like it was missing for awhile. The blade feels firm so run it, or figure a way to fix, or replace? I’m sure the factory didn’t leave it out for balance.
Probably put a small bolt with lock tight and run it as long as it doesn't affect the balance. What you want to look for are cracks in the blades.
Replace it, it's cheap insurance. If the blade comes apart it will cause more damage than what a new blade will cost you. Having it magnafluxed is a waste of money unless you have a exact style rivet to install, anything else will throw the blade out of balance and probably cause water pump failure, belt breakage.Cleaning up for paint and noticed a rivet missing. Looks like it was missing for awhile. The blade feels firm so run it, or figure a way to fix, or replace? I’m sure the factory didn’t leave it out for balance.
This I have seen wgat happens when they loose a blade. And also seen water pumps ruined from out of balance.Replace it, it's cheap insurance. If the blade comes apart it will cause more damage than what a new blade will cost you. Having it magnafluxed is a waste of money unless you have a exact style rivet to install, anything else will throw the blade out of balance and probably cause water pump failure, belt breakage.
Not everyone has a lathe at their disposalIf it were me I would machine a rivit on the lathe and fix it.
You just got to find the guy that was working on the assembly line in 1971. He has a pocket full of spare rivets out in his WorkshopNot everyone has a lathe at their disposal
I hang all kinda Used up/ broken parts Hanging around.. just kinda a cool thing, I guessIdk.. leave it or weld it.
Source a new one and hang that one on the wall even..
Wall art!!Sounds like replacing is the best, I probably knew that just wanted a few more thoughts. Thanks guys, not worth the worry.
Wow! That's pretty cool Man!The factory did balance these fans. They did it by adding a flat washer and riveting it on.
Never saw that.The factory did balance these fans. They did it by adding a flat washer and riveting it on.
Good point.replace all of them, balanced again!
340's usually came with a torque drive fan. Did you change it to the fixed unit? I am considering doing the same thing. What are your thoughts on it's cooling ability.
