Moparbrad
You don’t know me
This is a good parts car or an ambitious driver project. First off, it runs and drives. However, the engine has a healthy knock. 318, 904, 8 3/4 rear. Manual drum brakes, power steering non AC. The body still has the original paint. Some minor dings here and there. It has rust in the lower quarters, minor passenger lower fender and trunk center. There is a hole under the battery tray in the inner. Someone cut a chunk out of the left rear wheel house. Why? Who knows. The under side is solid and clean. The dash is mostly stripped but the speedo cluster is still there. Basically, it’s a what you see is what you’re getting.
$2500
No title. The car is located in Phoenix, AZ.
$2500
