They're in a 73 340.
Do you all think they'll play well with Edelbrock 60779 heads?
are those pistons taller than the deck?
They’re .020 above the deck
If that's all, then yes, they'll work with a closed chamber head. You need the right thickness head gasket for everything to play well together.They’re .020 above the deck
Bah humbug. Just look for some thick intake gaskets.Then the 60779 is a bad choice... You could run .065 thick Cometic head gaskets but then sealing the intake becomes a challenge...
Yes, that part I was able to figure outThose are .030" over pistons....
