So I have an A518 2wd transmission out of a 96 Ram 1500. I hadn't originally planned on doing anything with it but now I think I'd like to use it. My question is who makes a manual linkage to replace the computer based linkage
So is there a company that makes a kit 46re to work just like a 727 etc. I was hoping to use it in a higher end figure 8 car just because I had no other use for itThe actual shift linkage is mechanical, just like the 727. And a 96 is probably a 46re which is a electronically shifted trans, the 46rh would be hydraulically shifted just like the older transmissions
