Hooker Super Comp.headers
5208s sorry I'd didn't see thus earlier or could have rattled that off top of my head. Much experience with these on a 340 head :BangHead: as in the ports are too small and won't seal. The primaries are 1 5/8 small and the collectors are 2.5" iirc. They fit 273/318s great. Must use a port plate for larger port heads. They will leak out the bottom on a large port head. ~$500 used all day!
Mahalo for the info, I do have a rebuild 273 sitting on a engine stand. Maybe 273 /4speed would be enough for my 68 more door.
I have no info on post 66 fitment as the inners are +2 on each side and these are designed to go around the pre 67 narrow A's. If the site says they will fit, good luck. They are tight everywhere on a 65. Not sure howbrhey will handle a wider 67+
There you go.
Looking at the things they fit on that page, it appears they fit 64 threw 69 Barracuda's
I don't see that on the Holley page, Mike. All I see is that they fit the 64 65 and 66 cars. Where are you seeing they fit the later ones?
Good morning Rusty, oh it is on post 21 , I opened it up and this is what I seen sir.
Ok, I see it now. Says F body too? I think I'd do a LOT of measurin first. There's some big differences in all those cars. I think they may have something wrong there. I'd tread lightly. LOL
I agree, I have an f body here on the hill i could look at closely, I bet they exit inside the frame rail on an f body, if they do fit them.
Have a cool smooth day my friend, its going to be 100 here today.
Well if they also include the A body to 69, I would have to assume it's correct.
It would be worth looking into, but yes, good for the Barracuda, not sure about 67 69 Plymouth Valiant or not, there big ticket would be Barracuda and may not have known if they fit the Valiant model
They have the same front frame section, so I would surely think they'd be good for Valiant, too. Yours fit, right? lol
