Stop in for a cup of coffee
Test for combustion gases in coolant. If its pusing coolant out and not drawing it back in, its pulling in air from somwhere else. Someone with an airlift tool could pull vacuum and you would see it wont hold. I can do both the chem test and vac test.
I’ll see if I can find someone. Thanks
Putting up walls for new storage building
Yep they are great. I even built a small one
They have a whole complex of them here in Dalat. I think there are five separate courses altogether starting from beginner up to what they call the black course. But you don't just zipline from tree to tree. You need to traverse somewhat of an obstacle course each time you finish a line to get to the next tree to get to the next zipline. The zip lining is very easy. No issue there. The physical exertion comes in when crossing over to the next zipline on their obstacle courses. I paid $18 to do the whole course today. Takes about 2 and 1/2 hours to do the whole thing. I will admit I was a little wore out after I was finished. I shot some video and I'll convert it to YouTube and post it here next week. Was a lot of fun.
Morning rained here most of the night bringing in cooler weather for a couple days...:thumbsup:
Been a while but a pair of those, set of slip plates (easy) and a tape and you should be good to go.
