If you want a particular member for any reason, here's how you tag them. @Jim LuskHi I hope Jim Lusk sees my pictures I am rebuilding my LCAS In the 1 picture I have the level so you can see the unevenness and in the other other I have the level down towards the bumper plate I am wondering if the 1 side is bigger in diameter or is this thing bad thanks Tom
Those look just like mine the set you have for saleWell, i'm not Jim Lusk, who i do know, but another Jim, Jim Valuckas.
I personally have never seen a side of an LCA, with that big of a larger diameter than the other side.
But that side is most likely a bit bigger.
I wouldn't worry about it at all.
I think it's just the way that one was stamped out, back in the day, at whatever manufacturing factory did the work.
I currently have a pair of LCA's for sale in the for sale section on this forum.
Look at them for picture reference.
Apparently I was mistaken. I was out working on the front suspension and steering from my '70 Charger. The halves are offset slightly.Looks normal to me........
