nothingbutdarts
Looking to purchase this plastic piece on a 69 Dart. It seems to be long gone on the car & I do not know what it would be called.
Thank You!
Thank You!
There are 4 different size ones...they are spacers for interior panels...some cars had thick ones some thin...check your thickness to see what you have
Hi all,
I'm Reverse Engineering this small plastic part. Nothingbutdarts sent me the broken plastic retainer he has and I have it 98% complete to 3D print. I do need any photos and dimensions of the rear of a complete part so I can finish this up.
Also, if anyone knows the other thicknesses I can RE those too.
I suspect this is approximately what the tabs look like
Oh that's the mounting pads for the rear garnish trim! they snap into the rear dutchman panel
