Mechanical fan #
1969dodgedart
Big Block 440
Ontario,Canada
I have a 1969 dart with a 440 and a 3 row aluminum radiator, does anyone have this same setup ? And what fan / spacer would you recommend? It has 2 1/4" from the fins to the face of the water pump pulley fyi.
may be a 10,000 rpm flex fan in your future ...
I don't have that setup but I do have a Duster with a 400 and about that same space to the radiator. I've got the fan off right now and will try to remember to look at the part number and size of the spacer and post it. The fan is about an inch off the radiator.
I did not remember until today ... it's a 7 blade fan, about 17" in diameter, with a 1" spacer. On my car there's about 2-1/4" inches from the radiator to the nub in the center of the water pump. Part number on the fan is 2863200, it's stamped on every blade. I didn't see any numbers on the spacer.
I have a nice factory flex fan in the for sale section if you're interested.
