Stop in for a cup of coffee
Got an owee today but got me a Snoopy band aid and that makes any Bu Bu better.
Back from urgent care. Benedryl seems to have the sting area under control. But now if I do anything with left arm it hurts. (they ran EKG and it was good) Had a little bit of issue with it last few days, but not this bad. Think I pulled/pinched something in shoulder when I moved the toilet this past weekend.
Update: shoulder and arm was killing me. Went to ortho urgent care. By the time I was seen it was almost back to normal. Did see enough that I will be getting an EMG of that arm. What a f’d up day!
Guess I won't be driving the Duster anytime soon. I have no intention of getting at the linkage with the F'n winged a'holes waiting to attack. Must have a nest on it somewhere. Unless I am able to find and kill the nest, it will just sit till it gets cold. pretty much a year of no use. :BangHead:
Would throwing a tent over it and fumigating it do any harm to the Duster?
No but better idea yet… go to Home Depot, get the smoke/fog machine . Set it under the car, turn it on. It’s all water vapor so it won’t stink or ruin anything. Turn it on, walk away and watch from a distance. They will come out. This is how we used to get them out of the hay loft and out of various tractors and combines.
At this point, I really don't give a **** enough to do any of that.
Thanks but I just bought the 5 they had in stock I should be good . I’m curious how the 40 might do on the welds or if I’ll still need to whip out the grinder
Hey, I have a 120 I think if you need it
Easy fix eat some of my famous canned chili climb in the car and let her rip. Kills everything in a square block area but hard on the car seat. lol
I was using the stripping drum on the underbody and wheel wells. Did really well on the smooth area but not if there was contour. ....
It's heavy
I’m mostly stripping the roof and quarters, doors. So hopefully it’ll make quick work of them. Then it’s primer time!
