[SOLD] 1982 Dodge D150 SWB
5150DodgeBro
Pittsburgh PA
Rating - 0%
0   0   0
82 D150 $20k Had it sold on FB and the buyer vanished, go figure.
Was an old timer’s slant six “Sunday Truck” well kept w/84k miles (see last pic)
Now has a freshly rebuilt .030 LA360 w/mild cam, A833 OD, 3.23 SG
8 3/4 Rear Axle “flip” and Moog Van LCA’s to achieve the stance
INTERIOR 100% ORIGINAL except new and correct ACC Carpet
ALL ORIGINAL FACTORY SHEETMETAL INCLUDING BEAUTIFUL FLOOR BOARDS
Nearly $10k in gorgeous base/clear paint & body, has later 80’s grille and correct core support to fit
Thousands$$ in New Mechanical Parts: Clutch, Flywheel, Carb, Headers & Dual Exh, BJoints, Brakes, Shocks, Ignition System, etc., etc.
Many New Replacement and Hard-to-Find NOS Parts: Ram Hood Ornament, Fender Emblems, Sport Mirrors, Vent Window Bases, Door Handles, Tailgate Latch, Bumpers, Glass/Door Gaskets, Sweeps, etc., etc.
Truck runs, drives, sounds great for what it is and loves cruising the highway w/Overdrive. Has Manual Steer, Manual Disc Brakes. I got injured during the build, have a ton of $$$ in it and won’t be able to finish for a while. Lower body molding and wheel lips need installed. I have all those pieces in very nice condition as well as the new (expensive) molding clips. Fuel gauge and horns not working and heater core is bypassed. Most of the underneath is in its untouched, original state but you can see there is nothing hidden and there is no rot whatsoever. I won’t respond to BS, rude or the ridiculous. If you’re serious, DM and we’ll talk.
Located near Pittsburgh, PA Thanks fbbo!
