Help build a 408 stock block 5.9!
What fuel? The “boost later” plan kinda dictates a moderate compression ratio now and will keep the numbers down until that happens. If he’s ok with e85 once on boost, you can run the compression up high enough now that it’s not lazy NA, but careful piston selection is definitely a consideration to keep both (NA and boosted) combinations livable.
