Need cam guru thoughts/advice
Along the lines of Garrett above, do you know why the PO "didn't like" the Bullet cam? Or why it was installed 4 deg retarded?
Also, depending on TC flash stall, are you truly lacking any low speed torque?
Edit: I should have mentioned I'm no cam guru! But I do know a little bit from all my OEM engine years. :D
