Adult swim
Im going to say close ratio. With that rear gear and first in the wide ratio first gear will be too steep. I've got 4.10s and a 309 commando first gear. At the track you have to shift almost immediately after you dump the clutch. That said if you change the rear gear to the 3.54s I think you will be OK with the wide ratio.
