Shes alive an shes stayin alive!!
six pack said:
I would leave the gear drive off as well, remember, you're dad pitched it once already :wink:
my dads work had the same bearing that i needed for the gear drive,so he got me 20 of them just to start off with,so i hav plenty to play around with,an its easy to set it up now that we know how easy it is to pinch the bearings :bounce:
Not yet its still in her state of sleep,the rain has been killin me i cant open my hood or im screwed,my dad just got a SRT-4 so wev been messin with that an all his early X mas stuff,turbo,BV valve,timers an all kkinds of good stuff,so the cars on hold till it stops raining,they said it should clear up in a week or so,then im on it like flys on.....
Well shes almost done an ready to hit the road,FINALLY,i worked my a$$ off today get her all put back together,all the way from a short block to a complete,coolant filled engine bay,Im getting a Plasma cutter from my buddy so i can work on my trunk hole for my drop cage im making for my 16G fuel cell,run the lines an get a few small fittings here an there an then VRRRRROOOOOOOOMMMMMMMM!!!!!!!!!!!!!!! she should fire righ up,my good tranny is at my buddies shop,to get a full tear down a run throght its been a long time since its been in a car.After shes running an abile to mover her own *** around,i going to put in my dads 8 3/4 in,then start kickin some Butt agian on the road agian!!!!I cant wait ill keep ya all posted on the fire up! :thumrigh:
MIKE
We can hardly wait! :D Sounds like you're really close. So did you spin the motor over by hand a couple times just to make sure everything is assembled correctly? It sure would suck to have to tear into that thing again.
:twisted: :twisted: :twisted: WOW!!!n shes awake ya,an my god thats the loudest car iv ever been around in a long long long time,she fired up of the first shot!what a champ :cheers: she was hovin some carb probs,going to run a 600 DP sunday,to see if it fixes it,but man shes a screamer :shaking: :shaking: :shaking: mt head is still jacked up :shaking: :shaking: good times,mabey this week ill finally order my demon carb,well see,anyways thanks for all your help an support guys!it means alot to me,now need to make my trunk floor an get the 245's on an shes out to the muffler shop then to the streets to kill again! :cheers: :cheers: :cheers: :twisted: :twisted: :twisted: THANKS TO ALL
MI :twisted: KE
Well it's about time!!!! :mrgreen: :thumleft:
Glad to hear you got her running again.
:salut:
Congratulations !!!!!!!!!!!! :wav: I hope you enjoy many trouble-free miles of cruising :thumrigh:
My buddy got some of it on video yesterday when it was running kinda crappy,but it was running fine when i closed the coke :scratch: it seems tolike that alot but if u let it go she stars to surge! :scratch:
Somewhere in this thread I noticed someone said the timing marks should be cam sprocket on top and crank sprocket should both be on top.
Both of my manuals ( Haynes 71-89 Repair manual and How to Hot Rod SB Mopar's ) say that the marks should align cam on bottom and crank on top. Are these manuals wrong? When I degree'd the cam it was right on the money. If the books are wrong let me know as the engine is still on the stand with the head off, and should be an easy fix. BTW it's a '71 360 engine.
Just noticed later in the thread that the dots on top or bottom doesn't matter as long as the crank dot is on top and the cam dot is aligned on top or bottom and this only affects distributor placement. Whew, this really makes me realize that I've been away from engine basics WAY to long. Last engine I built was a 455 Pontiac for my '69 GTO way back in '85. Gee, I'm glad I got back into this hobbie. :thumrigh:
NO the books are right. Cam gear pointing down and crank gear pointing up.
:cheers: She firerd right up an idled great no probs,the new 650 Demon has me one happy camper,the reg. is set at 6psi an does she ever run like puring kittin well one crazy *** Lion,this is by far the best running motor ive ever been around,i never though that i would hav gotin it all right this time.She right on tap,u hit that throttle an shes right on tap no probs what so ever,this is one healty motor,an shes pissed an ready to hit the streets in a few weeks,she ready to prow the streets agian :twisted: :twisted: i wish u guys all could of been there to hear her run :thumrigh: An THANK YOU EVERYONE WHO HAS PUT AN EFFORT OUT TO HELP ME OUT IT MEANS ALOT TO ME :thumrigh: my buddy is a computer an photo/video master hes goining to help me out get some clips of her running uncapped for all of yur ears to bleed to :twisted: cant wait to put the muffs on so i can hear that gear drive pissin away :thumleft: cantwait
THANKS AGIAN GUY YOUVE ALL BEEN A BIG HELP TO ME AN THE ZOMBIE
MIKE :twisted:
If your SURE the timing is right, make sure you don't have some crappy rubber fuel lines that have collapsed. This happened to a friend of mine and it belched fuel every time. It was seending chunks of rubber into the carb. The car would only fire for a few seconds and then die.
nope shes all fine now all new 12 alum line with -8an fittings all the way to the carb,i didnt want mess around with all that rubber crud
Workin on it right now just got a good clip of her runnin today,an man on the suroundsound shes a beast :twisted:
Make sure she's getting fuel.
I had a brand new fuel pump on one of my small block rebuilds and it failed!
We could never figure out why it wouldn't light....then I realized, it wasn't getting any fuel in the carb.... Come to find out, the new fuel pump wasn't pumping...
Not wanting to read all 7 pages, what was wrong? Miloden timing set dot to wrong dot or bad fuel flow?
