Dartswinger70
Has anyone used flux core type welder to do their bodywork? Or is there a reason that they are priced so low(like you cant use them for anything)
Hay dgc333 I hate to tell somebody that they are wrong but you are, Lincoln dose have two levels of welders. The Lincoln Weld-Pac series of welders like the Weld Pac 3200 HD and my old Weld-Pac 100 are the Home depot and discount store versions. If you go to a welding store they should be selling the Lincoln Power Mig 140 and Power Mig 180. These are much better welders than the Home Depot versions. I am not sure if they still call the Home Depot versions Weld Pac's but if they aren't Lincoln Power Migs they are a second tier product line and they are not the same as Lincolns Power Mig line of products.
After, with some POR15 applied.
