lime / sub - lime green a body
Here is my 1970 FJ5 ......
took some new pics today! Its so nice to see the car outside, it is really bright when it has the sun on it compared to sitting in the garage.
a couple out by the crappy looking barn that will be partially covered up by the apple trees i planted saturday,
and then a couple on the cruise i took. I Went to pull it back in the garage and it just started to drive down the road! i dont know what happened! Gotta get that oil leak fixed (again) before it does that too many more times.
And i still can't figure out how to put text inbetween pictures.
Steve
DAM OIL LEAKS, APPLE TREES WILL LOOK GOOD THERE. WHAT WHEELS ARE YOU RUNNIN???????????//
Try this.
I am liking that color! Man I really have to consider that color for my duster. For the time being I need to choose a darker green color for my duster, to keep the door jambs. I plan on getting a lower budget paint job where I figure they won't car if they do the jambs or not.
Nice car...Question?
How can you be going 60 mph, in PARK and no FUEL? Now thats a fuel price I'd pay!
COOL!:cheers:
COOL!:cheers:
haha,
Thanks for the comment. I put that picture up just to see if anyone would notice that.
I put a hurst floor shifter in this winter, and i only removed the lever off of the column. And the gas guage doesn't work. I wish i could drive around like that on an empty tank, but i would have to be going down some long hills.
73dodgeman:
here is my wheel info from the sticky on the tires and rims forum:
Front
Wheel Brand: - Majestic 787
Size - 15X6
Offset: +6 mm
tire size: - P205/60R 15
Suspension mods: Front end rebuild and aftermarket sway bar
Rear
Offset: 0 mm
tire size: - P235/60R 15
Suspension mod: None
i bought them from www.jdwheels.com
If i were to buy them again i would have gotten larger diameter tires on both the front and rear
Steve
Hey 73Dodgeman, is your car out of paint yet? post some pictures of it! I have a 71 scamp with a dark green interior and im debating as to whether or not to paint it sublime, go green or sherwood green....the lime looks cool, just not sure if it will match my interior colour.
Its About 2weeks Away, Jams And Engine Compart. Are Done, So Far So Good:-d Ill Be Sure To Get Pics On Next Time I Go Check It Out. I HAD A 73 R.R. WITH THE SAME GREEN INTERIOR AND IT WAS SUB-LIME LOOKED REALLY GOOD TOGETHER.
