Is it a B-body or a B/E body tranny? If its a B/E body tranny with the dual shifter mounting pads its a fairly easy swap, I have one in my 68 Barracuda.
If its a B body only it will take some serious surgery to the torsion bar cross member because the single mount for the shifter sits under the the cross member. Also the bracket to relocate the shifter on bigblockdart.com won't work, you will need to fab up something on your own.
Don't forget you need to cut a very large hole in the floor and cover it with the floor extension hump to make room for the shifter rods. It will also require a new carpet.
