Nose job questions????
Irish_Fly
What would be entitled to put a 67' Dart front end on a 74' Swinger? I asked a "Mopar" Guy who comes into my work and he said just swap the fenders, grill, hood, and bumpers. Is it really THAT simply?
Well, since you have a 74 (impact bumper shocks), you'll have to re-drill for the new bumper mounts (I'm pretty sure). You'll also need the grille support that is located behind the grille.
Wow! So it is really simple then. So I wouldn't have to swap out core supports or anything? It's all almost bolt on? Just trying to get my info straight before I go off and start sourcing the parts :read2: Thanks for the quik replys guys
Other than the drilling holes for the bumper mounts. Yes it is just changing over parts.
The only other thing I can think you will need is the peice right behind the head light. Sorry don't know the name of it. But if you do need it it is a bolt on thing too.
Here is a pic of the things I don't know the name of. I think you may need to chang them out too. But am not sure.
This is a pic of Jonnydarts car. Hope he don't mind I used it.
Aren't the buckets are part of the front fenders? or is there some sort of extension?
Is the radius and lines between door and fender the same ? Any one actually completed this change ?
Looking at pictures of both it appears they all have the same body lines, there isn't a radius on any of the door/fender gaps, they all look vertical. Whether or not the lines actually line up may be something else, but it looks do-able to me. At the very least I would think it would be straightforward to put a 70-72 front end on it.
I have seen at several examples of people grafting 70 Swinger front and back ends on to 67 - 69 convertible cars, essentially making a 70 convertible. This suggests to me that the fenders should line up with the doors just fine.
I found this picture on the Net years ago... hope the owner doesn't mind me posting it. I guess if he did he wouldn't put it on the Internet, so here it is:
