Aluminum wheel cleaner
Thanks Mullinax, I`m going to try to find some locally and if not, well I`ll have to bite the bullet as you did and order some through the mail.
You're welcome!
I don't like recommending stuff because even though I am happy with it others might not. But this stuff REALLY works and I feel very confident in my recommendation. LOL!
Find it locally is your best bet. When I run out I will try to do the same but the way this stuff works and the amount I use ... it will be a long while.
I use mothers and have for about 20 years.
If the metal is real bad I will use semichrome first and then use mothers.
Semichrome is also great on stainless ,brass and works on plastic too
Raw or unpolished aluminum...Phosphoric acid. It will clean the metal chemically. It is usually the key ingredient in commercial wheel cleaners.
I use Wizards,great for polishing aluminum.Comes in a tin like bandaids.
I don't know if I should admit this or not ...but I was thinking that I had a bottle of stuff that I used to clean my truck aluminum tool box with years ago. I got rid of the truck and toolbox is why I really didn't think about it. Well I found it... and it looks just like the White Diamond liquid.
The name of tool box cleaner is called Diamond Brite Truck Box Polish. YOU CAN BUY IT AT LOWES! LOL!
The directions are exactly the same!
Longgone can you hear me?
Hmmmmmm......White Diamond...Diamond Brite????????........same stuff different bottle/name???????? 1/2 price at Lowes?
do you know if it has a clear coat on it if it dose you'll have to get that off first funny but i find with wheels oven cleaner works well at removing the clear coat just be careful it only takes a min or 2 then was it off
