Help Needed!!!
tmj91
member 10,000
have a 64 dodge dart 225 three speed on the column..not sure the kind it is...its non syncrho any input on that would be helpful....
now the problem...in first gear this morning there was a slight grinding nosie that got louder in second..then went away in third. shifting into second the noise came back then completely disengaged and could not get into anygear it just kept grinding in all finally somehow by the grace of god got it into third and managed to not need to downshift till i got to work....please help
Unfortunately I have never even seen a mopar manual tranny.
But here is a bump for you. 8)
Good luck.
New Process A903 1962-72 Cars & Trucks Inquire
Cast iron, top loaded case with side shifter linkage. Non-synchronized 1st gear with aluminum ring/pin assembly for 2nd/3rd. Main shaft 1st/Reverse gear has 29 teeth and the cluster gear has four steps.
It sure seems like I read some where that 2nd gear is synchronized !!
I wish I new more about helping you.
Could the shifting fork be wore or bent or even broken on one side ?
I hope a tec will jump in and give you some help.
from slantsix.org seems my throw out bearing is bad
thank mike!!:read2:
Is the noise there while in gear, or only when you depress the clutch to shift?
If only when the clutch pedal is depressed, then yes, I agree it's probably a throw out bearing that finally locked up.
BUT, you mention it got quieter in 3rd, which tells me something totally different, meaning there's internal damage and not being able to shift supports that theory, too.
Check your fluid level, those "oil spots" you may have noticed on the pavement probably aren't just engine oil.
Mark.
haha how did you know about my oil spots! haha :-D and yes it is there while im in the gear and when the clutch is depressed...
