AdamR
Big Member
My shifter mechanism seems to bind up and there is no linkage attached at the moment. I would think it would move freely with out the linkage ? Are these easily service or do I need to send it out or replace it.
Take it apart, be careful to keep track of what goes where. Clean it, lube it with some grease, and reassemble. If you do it carefully, it's really easy.
The shifter levers MUST be returned to their neutral position before you can move the shifter through the gate (to 3-4 position).
