Suregrip391
Ok, this should be an easy job but I cannot find anything anywhere. I am looking for someone to make me something simular to a disc type soft plug only FLAT (like a sheet metal circle) only in aluminum so it wont rust, the thinner the better as long as it wont crumple up like tin foil...LOL here's the specs:
2.750" diameter
.030 to .080 thick (not to picky) even if it was thinner slightly malleable would be ok (actually the thinner the better)
Drill two holes .785 in diameter (or close)
Holes need to be 1.5" apart from the center.
I would prefer it to have a brushed aluminum type finish if at all possible? Nice round clean edges and faces of the disc.
I just need two of these if anyone can help? Thanks guy's !!
2.750" diameter
