DynoMax headers??
eaw4209
67 dart with a 360. Does anyone have experience with the DynoMax headers? Clearance tuff spots, etc?
Typical tight spots are around the trans to block bracing on the passenger side, and the steering and starter motor on the driver side. Also, once you install the headers, I highly recommend a front antiswaybar, which will cut down on the amount of pavement your drivers side header gets to meet on a direct contact basis.
If you have not yet purchased the headers, stepping up to a slightly higher price range will get you a much better fit. My Hedmans far outdid the "blackjack" headers I started out with years ago. Also, swapping to the smaller Nippendenso starter found on the Dodge trucks from the 1990's will greatly improve your fit issues.
I had Dynomax on my car for a while. Not too bad IMO. The two places I had to clearance them were the areas around the steering joint and the idler arm. They are cheap and do hang low. I think it IS worth the extra money for better fitting headers but if these are all that is in your budget I think that they are pretty decent.
