After speaking with the Hughes Engines folks, I'm wondering if anyone has had luck installing their intake manifold gaskets dry; sans the typical RTV on the corners? I'm used to gaskacinch and the Permatex glue job, but am open to new ideas!
1qwikScamp said:i always put red permatex on the corners of the cork
headsbikesmopars said:20 years since I used the end rail gaskets. I use the black Mopar rtv, never a problem and I get it free...friend works at the local dealership. I run a 1/4" bead on the block end rails and use only a film around the water jacket openings on the heads. Good luck, Terry.
