MopaR&D
Nerd Member
The first time I pulled the 318 from my Duster I did it the 'normal' way, detaching it from the trans and pulling it out the top. I want to do it again, but since I intend to also replace the K-frame with a '73-up unit and convert from automatic to 4-speed manual as well as swap the rear-end I figured it would be easier to drop everything from the bottom and lift the car... Who on here has removed the drivetrain this way and what specific techniques are needed? Mainly, where is the transmission disconnected so it can drop out easily from the bottom?
