Radiator, pulleys, spacer, fan, for Slant 6
dustoff440
central fl
Pulled yesterday from running setup. Am installing 360 Magnum need cash to finish. These are from a 1970. I dont know when the set up was changed but I do know that the setup from 1970 was the same until the late 70's.
As you can see there is a ding in the radiator. IT DOES NOT LEAK!!! I would like to get $80 for everything but I am open to all reasonable offers. Thanks for looking. Will part out.
