This is a 1973 Plymouth Duster. It has big bolt pattern front disc brakes.It has manual steering and brakes. It has the spring relocation kit install with super stock springs with 3 way adjust racing shocks. It has a 8 3/4 with 456 gears with a spool.It has a pinion stubber and It has a brace on the rear end to make it stronger. It has 15x3.5" Weld Draglites on front and 15x10 weld draglites on rear with 28x12.50x15 M/T E/T Streets.It has a 4 inch cowl hood.It has a winners/Turbo action...
